PCIe-GPIB
Gateway PC will not Recognize my PCIe GPIB board.
the PC is only 8 months old.
Message 1 of 9
(5,920 Views)
I have a couple of suggestions:
- Verify you have the latest NI-488.2 and NI-VISA drivers.
- Try another computer.
- Try a different PCIe slot on the troubled PC.
If you are still having issues, respond back here.
Peter Flores
Message 2 of 9
(5,895 Views)
Hi
i took the Card to a pc shop and was put in 2 other computers. the card was not recognized.
i did a system restore and when i put the card back in i got a PCI standard PCI to PCI bridge installed.
should i have the drivers installed in order for my pc to see the card.
thanks for the help.
diegojaime
Message 3 of 9
(5,875 Views)
Yes, install the linked drivers and try it again.
Peter Flores
Message 4 of 9
(5,861 Views)
ok so i installed the the software and no luck.
Message 5 of 9
(5,853 Views)
Does Windows recognize the device at all in any machine (i.e. New Hardware Found Wizard)?
When installed, are there any entries in the Window Device Manager that may correspond to this device? Any Yellow Exclamation Marks?
Anything representative of this card in MAX?
If you can reply with the answers and some demonstrative screenshots, it would help lots!
Peter Flores
Message 6 of 9
(5,835 Views)
Hi
I Have put this card in 2 other computers and was not recognized at all.
 Currently I have it on my windows vista machine. When I first put the card in
a window came up
 Driver software installedPCI standard PCI-to-PCI Bridge installed ready to use. There is nothing in MAX or Device manager. I can’t find anything that looks like a GPIB card or IEEE.
Message 7 of 9
(5,831 Views)
Sorry no yellow Question marks at all.
Message 8 of 9
(5,830 Views)
Is this a new board? Has it ever worked on any PC?
This could be a faulty piece of hardware. Contact the Applications Engineering department via www.ni.com/ask for some suggestions on next steps.
Peter Flores
Message 9 of 9
(5,798 Views)
