open session failure
Hi I am issuing some commands to my device via NI-VISA through TCP/IP.
Here is what i do:
1.open session
2.some application specific commands
3.close session
These three steps are done multiple times and it seems most of the time the communication is fine. Once in blue moon i get an error from ni visa :
Failed to open session - Check TcpipSocket connection at address x.y.z.a(Failed command: OpenSession)
I check the device and it is running on the ip  x.y.z.a, i close ni visa and reconnect to the same ip and issue *idn? i get a valid response back. I dont understand what is causing the open session to fail intermittently
thanks
(5,637 Views)
open session ONCE at start of program
close session at end of program
(5,631 Views)
Hi nyc,  thanks for the quick reply
heres what i do..
I do open session once. do the application code and close the session on that unit
but sometimes i have two or more devices connected. So i  close session on the existing unit and open new session on another unit do application code and so on.
after some time when i get back to the old unit (for which i previously closed session) to open session, it fails sometime
(5,629 Views)
You can leave the session open, even when you are talking to multiple instruments.  Imagine a test system with 10 ethernet instruments.  Are you telling me you would open and close the sessions each time you change which instrument you are talking to?  No.  Open a VISA session for all of your instruments and then close them when your software shuts down and your life is a lot simpler.
(5,610 Views)
Hi crossrulz,
But technically I should be able to open and close session multiple times, which i am able to do most of the times.
I will try your suggestion but if it works, i am not sure what the root cause of this intermittent open session exception was.
I saw a similar post where ni-visa read hangs for driver V5.0.3 and above, i am using ni visa version v5.4, I dont know if these are related
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/VISA-Read-hangs-Get-Resetting-VI-dialog-on-ab...
thanks
(5,582 Views)
Hi wwwwww,
I did a quick search for your error, but didn't find anything that seemed related.  It's obviously not the a perfect explanation, but nyc is right.  Opening and closing sessions once will very likely fix your error, since that's the way those VIs were designed to be used.
(5,539 Views)
