out buffer copied in input buffer with Rs232
i'm having trouble with serial port  and don't know what to think about
i 'm sending commands to a device (hmp231)  and when i'm reading the message on the input buffer i recover the command
that a thing i never met before , could it be an error of coding ? did anyone meet this trouble ?
i thought it could be a specificity of the device but when using hyperterminal i just recover the response with out the command  ...
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,290 Views)
Accepted by tinnitus
Either your instrument has echo on, but then it should also be the case in hyperterminal or you have set hyperterminal to echo off.
Or you fill the buffer via a shiftregister yourself. Please send the vi you are using to check this.
(3,288 Views)
nice
the device can be configured with or without
Tinnitus
(3,286 Views)
