pc don't connect with gpib-enet/100
Hello.
In my pc i have instaled the LabView 7.1 student edition (with the drives of the 7.0) and i am trying to connect the pc to a gpib-enet/100.
After the instalation the MAX don't recognize the GPIB, the ligth "PWR/RDY" of the enet/100 is blinking fast, but i think the IP is the correct one. I don't now what to do, can anyone help me?
Thank's.
(2,968 Views)
If MAX do not recognize  the GPIB, it means it is not installed correctly.
Did you install the drivers after having installed LabView, it is the good way to operate.
What drivers did you install, you can dowload "NI-488.2" at this address:
http://digital.ni.com/softlib.nsf/websearch/1DDE5C48F30C2C658625702000681295?opendocument&node=132060_US
It is the apropriate driver for your application.
You can also go to this address to have more information about the installation and configuration of your device.
http://www.ni.com/support/gpib/enet95/default.htm
Hope I could help you.
Johan G. NIF
(2,936 Views)
