What is the command to aquire the data array from a Agilent impedance analyzer into a Labview vi?
I realize that this might be the wrong place to ask this question but I’m trying the reproduce the plot displayed on an Agilent 4294A impedance analyzer to a plot on a Labview vi.  I was wondering if anybody has tried to do this and what command I need to send to the impedance analyzer.  Thanks for any help somebody might be able to give me.
Eric
Message 1 of 8
(5,115 Views)
I forgot to mention that I am using GPIB interface between the computer and the impedance analyzer.
Message 2 of 8
(5,106 Views)
I can't find a driver for the 4294 on either NI's or Agilent's web sites. NI does have a driver for the 4194 here that you could look at and see if the instruments are similar. The actual commands should be in the programing manual for the instrument so you should be able to try them out yourself. From MAX, you can establish communication and do writes, reads, and queries. You could also try using the Instrument I/O Assistant once you've identified the commands.
Message 3 of 8
(5,102 Views)
NI is interested in developing CVI and LabVIEW drivers for the Agilent 4294.  We have been unsucessful in our attempts to secure loan of an instrument from Agilent.  If you can loan the instrument for approimately 3 months, NI will develop the driver.
Jason Hobbs
instrument.drivers@ni.com
Message 4 of 8
(5,093 Views)
Thanks for your help guys.  I would loan out the instrument to NI, but Im only an undergraduate research assistant, so I don't really have much pull around here.
Message 5 of 8
(5,081 Views)
i think i can help you i have written programmes for hp4294A in labview if u want i can sent them to you
tarun_teo@rediffmail.com
Message 6 of 8
(5,064 Views)
Please submit your VIs for the 4294 to the Instrument Driver Network at:
https://sine.ni.com/apps/utf8/niid_web_display.sub_driver
Message 7 of 8
(5,058 Views)
NI is currently developing a VXIpnp driver for the 4294 and will begin a LabVIEW driver soon.  A beta quality driver should be available in the May/June timeframe.
Message 8 of 8
(4,835 Views)
