please help me is any toolkit is required for running visa blocks?
please help me is any toolkit is required for running visa blocks? because whenever i run any serial project in labview it gives Error 1 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->serial communication.vi error... please help me waiting for your guidance.
Message 1 of 9
(5,638 Views)
No, all that you need is NI-VISA and the driver for your USB-Serial converter If that is what you are using. Verify that the port shows in Windows Device Manager and in MAX.
Message 2 of 9
(5,633 Views)
thanks for your consideration ...i have drivers also but still  getting same error.. my IV is attached with this message please review it.
Message 3 of 9
(5,612 Views)
Can you attach images of the block diagram and front panel? I'm posting from my phone.
Message 4 of 9
(5,608 Views)
Did you choose a serial port that actually exists in the VISA Resource control before running your VI?
Message 5 of 9
(5,584 Views)
these are the images please check them
Message 6 of 9
(5,562 Views)
Message 7 of 9
(5,562 Views)
Your VISA Resource Name control is blank. You have to select a valid name. Click on the pull-down menu (the arrow on the right side) and pick your com port from the list.
Message 8 of 9
(5,554 Views)
Just as I was hinting at in my last post:  you have to select a valid serial port before you run your VI.  Using the dropdown on the VISA Resource control will show which ports are available for you to select from.
Message 9 of 9
(5,539 Views)
