Are you able to communicate with the instrument at all using the GPIB-232/485CT-A? Just to make sure, you are using the RS232 port on your device. correct? In other words, your setup should look something like this: Computer(with GPIB board)<-->GPIB Cable<-->GPIB-232/485CT-A<-->Serial Cable<-->MINOLTA meter.
To communicate with the meter, your GPIB-232/485CT-A should be configured for "G Mode". Is that the configuration you currently have? See
the manual for more information on this configuration. Once you have it configured, you should be able to talk to the meter.
Unfortunately, as far as writing a new driver for the instrument, I am afraid I can't help much with that. A few questions though...
Does the current driver you have use the NI-VISA API? ( I am assuming it does). If so, you should be able to use the same driver with little or no modifications. If you want to post the driver, I can take a look at it and let you know what I think. Hope this helps. Thanks!
Message Edited by _Belle on 04-10-2007 06:32 PM
Ebele O.
