pxi 8431 not recognised
I am running a PXI 1000B Rack with Visa vesion 5.0.2 and MAX vesion 4.6.1  In MAX the PXI rack and DAQ cards are present but in the COMs drop down menu I cannot see the 2 Port RS485 card and windows gives a message on boot up that it is trying to find the driver for 'PCI Simple Communications Controller', probably reason whuy its not present in Coms list.
I have tried removing VISA and re-installing also tried reinstalling MAX but no joy.
Anyone got an idea?
Jack
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
(3,423 Views)
Accepted by jack1
The card comes with NI-Serial. Did you install that?
(3,413 Views)
Thanks for suggestion Dennis and no to your question because the board came back with a rack and some of my equipment for upgrade from a customer. I knew it would be something obvious but I ended up un-installing Visa and MAX and re-instaling the device drivers this evening from my ver 8.6 CD's, which sorted out the probem.
I have copied your link and will load this in future.
Thanks again,
Jack
Labview Version 8.5
Labview Version 8.6
(3,410 Views)
