pxie-5160 issue using IVIScope driver
I am having issues getting my PXIe-5160 4-ch scope to work with the IVIScope drivers.  I am taking a measurement over 400us with a min record length of 10,000.  When I prepare a reading on channel 0, this works fine.  But then when I go to do the same thing on channel 1, it gives me the attached error message.  I do want to be able to capture data on both channels, or even all four maybe.  I do not see anywhere to set the sample rate.  This seems to be a read only attribute that the device should be figuring out itself.  I do not see the problem as at 400us long, 10,000 samples, that's only 2.5e7 rate needed which is way slower than the max of 1.25e9 it can do.
(3,099 Views)
Accepted by topic author BretRidgel42
I had my math off.  I was requesting 4us not 400us.  So that does in fact exceed the capabilities of the card at 10,000 samples.  I adjusted the min record length to 5000 and it works fine.
(3,071 Views)
