Is there an instrument driver for Heraeus Vötsch Test Chamber VMT 07/35?
The equipment is very old with only RS232 interface. I can't find the manufacturer's website. Is there any solution?
Message 1 of 65
(16,336 Views)
[SRQ 211326]
I haven't found a driver for the test chamber you mention but I found the manufacturer's homepage:
http://www.kendro.com/heraeus.html
It looks like Heräus is now a subdivision of Kendro. Please ask the vendor if a LabVIEW instrument driver is available. If not it shouldn't be too difficult to control the device using VISA serial commands in LabVIEW. Please refer to the manual of the device for the valid command set.
Jochen Klier
NI-Germany
Message 2 of 65
(16,301 Views)
hi,
i am looking for the same driver. have you made any progress on the driver? i referred to the recommended website but found nothing!
Message 3 of 65
(15,721 Views)
About two years ago I used a Vötsch VTS 4150 in an application. I wrote some VIs to communicate with the chamber. Do you know the communication protocol of the VMT 07/35 ?
Message 4 of 65
(15,717 Views)
i am not entirely sure. the only information i found was the following text file with an instrument driver. but i could not figure out how to use or compile it
http://duteela.et.tudelft.nl/~bertb/veedrivers/hpids/VMT0735.id
Message 5 of 65
(15,717 Views)
This will not be of great help (at least for me) !
What we need is the list of the different commands to communicate with the chamber through the serial port. The manufacturer should be able to give you this protocol.
Message 6 of 65
(15,711 Views)
Did you already looked at this site
I have a manual for the HC4015, 4030, 4055, 4120, 7015, 7030, 7055, 7120. The ASCII protocol are two pages with a read and set data command.
Let me know if this can be of any help.
Message 7 of 65
(15,707 Views)
Hi, K C.
Is it possible that you can send the manual for HC4015, 4030 and 4055.
/Martin
Message 8 of 65
(15,395 Views)
Hi Martin,
I cannot send you the manual I only have a paper copy. I can scan the pages with the communication protocol for you.
Message 9 of 65
(15,386 Views)
Hi K C,
Thanks, that would be great.
/Martin
Message 10 of 65
(15,382 Views)
