Is there an instrument driver for Heraeus Vötsch Test Chamber VMT 07/35?
Hi everybody,
I am trying to figure out how to control a Vötsch VT4010 climatic chamber with my PC.
I have the pdf file of the protocol (see attached file), but I don't understand the difference between 'ASCII-1' and 'ASCII-2'. Which one should I use?
Can anybody please send me a .vi (Labview file) to control the chamber?
Or just some good tips, 'cause it seems awkward to me to communicate with that chamber.
Thank you,
Marco Ranieri
Message 61 of 65
(5,520 Views)
@Marco R. wrote:
Hi everybody,
As I did understand it, you can use either. You just have to decide which one.  I would try the ASCII 2 protocol first, because it doesn't use any checksums. So you can use a simple terminal program to make tests.
Sorry I can't help you with Labview Vi's. We are using Labwindows here.
You will have to look into Labviews string manipulation .vis first to build a command string from the parameters
and then send that string with the serial interface control VI to the chamber.
You probably want to control at least parameter 1 ( which is usually temperature), parameter 2 ( usually humidity)
and digital channel 1 ( usually switches the chamber on/off) . For all other values you might be able to use constant values ( except you have additional needs).
Message 62 of 65
(5,500 Views)
Thanks Markus for your answer!
I'll try to send some string in the ASCII-2 protocol then.
bye
Marco
Message 63 of 65
(5,478 Views)
Look at
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/How-to-communicate-with-VOTSCH-VT-7004-Therma...
All (?) Haraeus Vötsch chambers have the same serial communication mechanism
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 64 of 65
(4,972 Views)
I want to control the chamber kindly give me manual and operatinf instruction
Message 65 of 65
(2,883 Views)
