Is there an instrument driver for Heraeus Vötsch Test Chamber VMT 07/35?
Hi Dave,
I have attached the pages from the Operations Manual about the connections to the chamber.
Hope that will help you.
/Martin
Message 21 of 65
(9,320 Views)
Thanks alot Martin!  This was what I needed.  Now I just need to hope that my pinout is the same on my chamber.
Message 22 of 65
(9,314 Views)
In the manual I have (also another type of chamber) the same pinout is used.
Message 23 of 65
(9,308 Views)
I have problems with VT4010, i have the manual but i'm not sure about the commands, eg        $00I<cr>     --> read chamber, but i get not response, i'm sure that the configuration is OK......
I'm trying to communicate through Labview, by using serial interface RS232 and ASCII strings.
Message 24 of 65
(9,144 Views)
When I get back to work next week I'll post my latest Heraeus VIs.  These control both the older and the new oven controllers.  They might work for you. Even if they don't they might give you some clues as to getting yours going.
Regards, GGT.
Message 25 of 65
(9,138 Views)
Hello all,
I had problems with VT 4010, the problem was only that in the user manual was not write the wiring of RS232  25Pin to 9Pin.
The wiring is the following:
25Pin  -->  9Pin
2 --->  2
3--->   3
7--->  7      (NOT 2 with 3 and viceversa).
Message 26 of 65
(9,078 Views)
Hi All
I am trying to control VT 7004 through LabVIEW
As the first step we made DB9-DB25 adapter as in the attached DB9-DB25 Adapter diagram
After that we tried with the heraeus VI's given in this topic, it seems no communication is going with chamber
i have few doubts
1) is the DB9-DB25 cable i made as shown in the fig is correct?
2) In the VI it is mentioned that we have to press "EXT" switch on the chamber for remote control from PC
 could i use these configure, setconstant and tempdwell VI's for  VT 7004
Pradeep
Message 27 of 65
(9,057 Views)
Hi Cencio86, All
I have doubt in 9PIN to 25 PIN connector
9PIN          25PIN
2        --->   2
3        --->   3
5        --->   7
am i correct?
Is the vi's given in this thread worked for VT4010, i want to use these for VT7004
Pradeep
Message Edited by appala on 03-31-2009 03:39 AM
Message 28 of 65
(8,877 Views)
KC - Any chance you could scan the basic operating instructions for the  Heraeus Votsch HC 4030 Humidity chamber ?
Cheers
Bob
Message 29 of 65
(8,500 Views)
Hi Bob,
No problem but I at this moment I am sitting at home on the couch (gout)
As soon as I get back to work I will look into it.
Message 30 of 65
(8,486 Views)
