10-18-2012 09:49 AM
Hello:
I have a Keithley 2701 with TC's attached to channels 102 and 103. I have been successful in logging data from one or the other channel but not both at the same time. Bellow is my code.
from pyvisa.vpp43 import visa_library
visa_library.load_library("/Library/Frameworks/Visa.framework/VISA")
import -
import time
keithley = visa.instrument("ASRL1")
keithley.write('*RST')
print keithley.ask('*IDN?')
keithley.write('TRAC:CLE')
keithley.write("INIT:CONT OFF")
keithley.write("TRIG:sour IMM")
keithley.write("SENSE:FUNC 'TEMP', (@102)")
keithley.write("TEMP:TRAN TC, (@102)")
keithley.write("TEMP:TC:TYPE K, (@102)")
keithley.write("TEMP:RJUN:RSEL INT, (@102)")
keithley.write("SENSE:FUNC 'TEMP', (@103)")
keithley.write("TEMP:TRAN TC, (@103)")
keithley.write("TEMP:TC:TYPE K, (@103)")
keithley.write("TEMP:RJUN:RSEL INT, (@103)")
keithley.write("TRIG:COUN INF")
keithley.write("ROUT:SCAN (@102,103)")
keithley.write("ROUT:SCAN:TSO IMM")
keithley.write("ROUT:SCAN:LSEL INT")
print keithley.ask("READ?")
My output from this is:
+2.24654121E+01 C,+61.898106SECS,+00239RDNG#
I really want to get both outputs from 102 and 103, should i be using READ?
Thanks.
--Vivek
10-18-2012 12:22 PM
2701 is the mainframe. What is the plug-in board you are using?
Does the plug-in board have anything unusual about channels 2 and 3?
10-18-2012 01:33 PM
The plug in board is a 7700 multiplexer.
10-18-2012 08:15 PM
11-14-2012 01:36 PM
If you can't figure it out from the manual, suggest you should your code to the Keithley forum...
