query spectrum analyzer trace information into an array
I am currently working with LabWindows/CVI, and I am trying to query spectrum analyzer trace data (comma
separated data) into an ASCII format array (str_trace[]), where I use the
following three different kinds of commands; however, neither works.
No.1: ViQueryf(HP_E4407B, "TRAC:DATA? TRACE1 \n", "%s\n", &str_trace);
No.2: sprintf(write_buffer,"TRAC:DATA?TRACE1 \n");
      Send(0,HP_E4407B,write_buffer,strlen(write_buffer),1);
      Receive(0,HP_E4407B,read_buffer,numToRead,256);
      sscanf(read_buffer,"%s\n",&str_trace);
No.3: sprintf(write_buffer,"TRAC:DATA?TRACE1 \n");
      ibwrt(HP_E4407B,write_buffer,strlen(write_buffer));
      ibrd(HP_E4407B,read_buffer,numToRead);
After getting the arry of str_trace, I am doing the following to separate them:
       char *result=NULL;
       result=strtok(str_trace,",");
       while(result!=NULL){
           data[i]=atof(result);
           i=i+1;
Please help me to point out where the errors are. Thanks a lot!
(4,693 Views)
In the previous post, the retrieving command is actually: "TRAC:DATA? TRACE1". If anyone knows the answer, please let me know. Thanks a lot!
(4,683 Views)
What is the HP_E4407B parameter in your examples ? How do you set it ? For the first example it should be an instrument handle , returned by viOpen();
(4,672 Views)
HP_E4407B has been set to be my device.
(4,669 Views)
Hello yfguan,
       I recommend that you use the IVI Instrument Driver for your instrument.  You will also need to download the latest version of the IVI Compliance PackageHere is something to help you get started with IVI in CVI.
Cheers,
NathanT
(4,658 Views)
Hi NathanT,
    Thanks for your suggestion. However, is any possible ways I could just write several commands to do this, like I shows in my previous post? Thanks!
(4,647 Views)
