"*IDN?" command
when I send command "*IDN?" and check for errors
ibsta = 130
iberr = 1
here is the sequence of commands i sent
ibfind gpib0 board
ibsic
ibcmd "@?\x22"
ibwrt "*IDN?" /* at this point i get an error do i need to send a time out command?
I looked up the error for iberr where (1) means function requires GPIB board to be CIC. however i sent the ibsic command.
I also looked up the ibsta error but i am not sure how to interpert the error code i am getting
(5,374 Views)
The iberr field only represents an error if the ERR bit of ibsta is set (0x8000). Since ibsta is less than 0x8000, no error occurred during this call. If the call really had an ECIC error, ibsta would have been 0x8100 (or 0x8110) and iberr would have been 1.
(5,374 Views)
It's ok but could you tell us why Ibsta and Iberr were diffrent that zero ?
thanks for answer
Gorgo
(5,374 Views)
ibsta indicates the status of the controller.
0x130:
0x100 = I/O is complete (not in progress)
0x20 = Controller is "Controller in Charge"
0x10 = The ATN line is asserted
iberr could be used for internal purposes. The only time iberr has any indication is if the error bit (0x8000) in ibsta is true. At that time, iberr indicates what error occurred. iberr should be ignored at all other times.
For more information, refer to the NI-488.2 help. There is an entire topic dedicated to ibsta and iberr.
(5,374 Views)
