Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
programming the serial port
fanta
Member
04-11-2002
04:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I use one of LABVIEW examples to test my serial port (COM2). I received no errors and also no string back. Can somebody help or show me an example I can use? I am working under Windows 98. Thanks
0
Kudos
Message
1
of 2
(3,323 Views)
Reply
Re: programming the serial port
Chris_Rake
NI Employee (retired)
04-11-2002
08:50 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I believe some of the examples require a loopback plug or a null modem cable connected between two ports. Which example are you using?
0
Kudos
Message
2
of 2
(3,323 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
