programming the serial port
I use one of LABVIEW examples to test my serial port (COM2). I received no errors and also no string back. Can somebody help or show me an example I can use? I am working under Windows 98. Thanks
(3,337 Views)
I believe some of the examples require a loopback plug or a null modem cable connected between two ports. Which example are you using?
(3,337 Views)
