"VISA: (Hex 0xBFFF0015) Timeout expired before operation completed signal recovery" with Agilent GPIB card
Now you've disable the controller from sending EOI?
The EOS byte does not look right. It's a line feed which is 0xA. I don't remember if that field is hex or decimal.
Message 11 of 13
(6,205 Views)
Thanks Woodster.
This also fixed my problem, it says timeout error, but it is really conflicts between dlls.
BR,
JMA
Message 12 of 13
(6,061 Views)
Hi all
I am using the NI VISA I/0 to talk to Keithley SMU 2410 using a PROLOGIX GPIB-USB Controller.
I have correctly configured(I think) the SMU to VISA using the GPIB connection but I'm getting the same timeout error as mentioned in this thread.
The command outputs are the following:
_____________________________________________________________________
Command: *IDN?
   Write: Write Operation (*IDN?)
              No Error
   Read: Read Operation
              Return Count: 82 bytes
              KEITHLEY\sINSTRUMENTS\sINC.,MODEL\s2410,4116375,
              C33\s\s\sMar\s31\s2015\s09:32:39/A02\s\s/J/M\n
After this, I try to use the following command sequence for measuring current by sourcing voltage:
*RST
SOUR:FUNC VOLT
SOUR:VOLT:MODE FIX
SOUR:VOLT:RANG 0.2
SOUR:VOLT:LEV 0
SENS:FUNC "CURR"
SENS:CURR: PROT 100e-3
SENS:CURR:RANG 10e-3
OUTP ON
READ?
The output I get after I read each of these commands is:
Read Operation
Error
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
I am struggling to understand why the I/O is not able to souce voltage on the sourcemeter even when it responds well to the *IDN? command.
Let me know if any more information is needed.
Thanks!
Message 13 of 13
(4,012 Views)
