Can you be more specific :"you need to have no value applied to the instrument ", what does it mean,because when you initially switch on the instrument the PWM sets according to laser power that is 0dbm and the setting is manual.
Also I have tried to put the subvi setpwmparameter in the initialise subvi , that is where it gets the pwm channels,is that correct?
Also do both the subvi's are needed the setpwm parameter and the setinitial range?.
Thanks.
Madhu
