random character serial
File>Properties>Settings.
Message 11 of 14
(1,717 Views)
I get the same thing as previously. ie: a message every 30sec displayed on the hyperterminal window
Message 12 of 14
(1,714 Views)
You may have a problem with data synchronization. You have the termination character disabled with the VISA Configure Serial Port. If the device is appending a CR or LF after each piece of data, then you want this enabled. You could also add a VISA Flush buffer right after the VISA Configure Serial Port to clear whatever might be in the buffer before you start doing your read.
Message 13 of 14
(1,710 Views)
The Visa Flush Buffer clears some of the random characters but also, it doesn't give me the complete message I intend to receive.
Message 14 of 14
(1,688 Views)
