real time adquisition
I'm tryin to get a real time signal into my computer, it's realy important to get this signal in an accurate way, but every time I move the mouse the signal sample is way much faster than the signal captured without moving it...and I really need a continous sample no mather what happens in the computer..I mean if somebody is moving the mouse or playing with it, the time sample should be the same...What can I do?
Carlos
(3,473 Views)
> Thanks
> Carlos
Hi Carlos,
Looks like you need either a card with an onboard DSP like what UEI
provides (www.ueidaq.com) or you need to run a real-time operating system.
BTW, I doubt you're trying to collect real-time signals using GPIB. Your
questions have a better chance of getti
ng answered in these groups:
natinst.public.daq.real-time.general
natinst.public.labview.real-time.general
I'm using a news reader so I have no idea what these look like on NI's
website.
(3,473 Views)
Hello Carlos,
Thank you for contacting National Instruments.
Would you please respond with what hardware and software you are using to acquire this data? It would also be helpful if you posted the code you are using.
I will be happy to help when you respond with more information.
Sean C.
Applications Engineering
(3,473 Views)
Hello feuerwehr,
I am assuming that you are using a DAQ card to acquire your signal.
One possible solution is to use an external clock to acquire your signal instead of using software timing (i.e. loops and weight functions in LabVIEW). Software timing is subject to inconsistencies caused by the load placed on your processor by background tasks.
I hope this helps! If you have further questions, let me know.
Matthew C
(3,473 Views)
