visa installation
I'm trying to make a self executable file to install a labview stand alone application. This one requires the visa runtime engine, so following the application note instructions I'd created a batch file. The problem now is that installer first setup the VI application, then when is the visa instaler time, it stops and seems can't go on. I'd also tried to install the two applications manually and things go the rigth way.
What do you think about, can you suggest me something else otherwise a good cup of coffee?
Thank you for your attention
Chyrus
(3,090 Views)
Hello chyrus,
Thank you for contacting National Instruments.
There are a few Knowledgebase articles that explain in detail how to create and use batch files to install additional drivers with a LabVIEW application. Use the following link to access these KBs:
http://digital.ni.com/public.nsf/websearch/E09BA0E2F31D304F86256A640070058E
Note also that additional information is available under Related Links at the end of the article.
If you are still having problems or have additional questions after reading through these KBs, let me know.
Matthew C
(3,090 Views)
