receiving serial commands from microcontroller to serial port of PC with LabVIEW
Hi all,
I am developing an application where i need to interface serial port of PC with Labview and a microcontroller. I need to receive and transmit serial commands to microcontroller in a packet format(The packet of 5 bytes that includes header, data length, id, data and checksum).
I have successfully tested the VISA serial read vi and serial write vi for Tx and Rx 1 byte data , but have no idea of handling packet format where i also need to validate the  packet data received.
Kindly provide me any suggestions.
with regards,
Sri
(4,475 Views)
You've got the first step. As you receive each single byte, see if it's the header. Once the header is found, read 4 bytes. After that, you are synched and each read would be 5 bytes. The string to bye array function would then be used and you can index any element you want.
(4,468 Views)
