rs 422/485 - meaning of pinout abbreviations
Hi
I need to work with RS422, using the NI USB-485 connector. I've found the pinout descriptions in this manual : http://www.ni.com/pdf/manuals/373170d.pdf
However, the pinouts are all abbreviations :
Pin 422/485
1 GND
2 CTS+ (HSI+)
3 RTS+ (HSO+)
4 RXD+
5 RXD-
6 CTS- (HSI-)
7 RTS- (HSO-)
8 TXD+
9 TXD-
GND is ground, but I don't know what the others are, and I found no definitions in the manual. Can anybody tell me what these all mean ?
(4,811 Views)
The pins you will most likely need are the TX (transmit, data goes out) and RX (recieve, data comes in).  The rest of various handshaking and addressing lines (RS-485 has an addressing scheme).  All of the signals are differential, so there is the + and - for each signal.
GCentral
(4,808 Views)
