running function generator (HP 33120) at higher than 1KHz by Labview
Dear all
To run a function generator HP 33120 by Labview, I downloaded a driver "Agilent 33XXX Series", also attached with this message. But the vi files (e.g. "Standard Waveform.vi" or "Arbitrary Waveform.vi" ) available in this driver, dont allow the function generator to generat a signal of more than 1 kHz, while I need about 200 kHz. Manually the function generator can easily generate a signal of 15 MHz.
So I need a driver/vi of this function generator which can make it generate a signal at about 200 kHz. Kindly help me.
Thanks in advanced
Regards
Faheem
(3,320 Views)
The driver does allow you to set any frequency. What makes you think you cannot?
(3,316 Views)
Accepted by faheemkhan
Dear Dennis
I think I had hardware problem where I was able to change frequency from 1000Hz to 999Hz and so one but I was unable to increase from 1000Hz to 1001hz and so on. But now it is solved.
Thanks again
(3,301 Views)
