scope Acquisition
I want to communicate with scope by parallele port (LPT) using labview, i`ve download the driver of scope,but the PC hasn`t also detect the scope,
can u help me.
Jamal.
Message 1 of 11
(5,340 Views)
What kind of scope has a parallel port connection? What is the make and model and where did you get the driver? How are you trying to detect the scope?
Message 2 of 11
(5,334 Views)
I use scope from tektronix Ref.: TDS3054B
I download driver from NI site.
I use PC wizard to detect device but i don t have answer.
Jamal.
Message 3 of 11
(5,327 Views)
That scope does not support remote programming through the parallel port. Only Ethernet, GPIB, and RS-232. The printer port on the instrument is used for - printing (big surprise).
I'm not familiar with a program called PC Wizard. If you want to use an NI tool, you can start MAX (Measurement & Automation Explorer). You can detect and find a GPIB instrument, detect or configure an Ethernet instrument, or talk to a serial instrument.
Message 4 of 11
(5,325 Views)
So I don t have a ohter choice, I have just ethernet to communicate with scope becauce i don t have GPIB or Serial port in the scope.
how i do thant please.
i have already use MAX but it does not give me like choice the LPT, i have just the COM1 .
Jamal.
Message 5 of 11
(5,321 Views)
i have already use MAX but it does not give me connexion with ethernet cable, when i do TEST.
Jamal.
Message 6 of 11
(5,322 Views)
In MAX and at Devices & Interfaces under Configuration, right click and select Create New>VISA TCP/IP Resource. After that, what you do will depend on how the instrument is setup - whether it is on the same subnet as your pc or isn't.
Message 7 of 11
(5,320 Views)
I do that but when i type the adress IP for scope, and i click test the connexion is not good.
what s the mater.
jamal.
Message 8 of 11
(5,314 Views)
Do you get any error code or message? Is the instrument on the same subnet as your pc? How are you connecting to the instrument? Through a hub or direct cable? If it's a direct cable, is it a cross-wired type? Can you ping the instrument?
Message 9 of 11
(5,308 Views)
I don t have any message of error,
when i test connection with the scope, it s not connect,
i use direct cable.
and I cant  ping the device.
but windows make me that cable is connect.
Thank u.
Jamal.
Message 10 of 11
(5,296 Views)
