serial communication on LabView 5.1
I have an old program running on LabView 5.1.  I want to add code to read a sensor over an RS-232 line.  The device is connected to Com1 on my computer.  Using Hyper-terminal I can communicate with the sensor device.  I set the device to 9600 baud, 8 - N - 1 and send the command "SEND" and it returns the information.  Going into the Labview 5.1 example serial communication VI if I send the "SEND" command, the program times out with no return characters.  How do I start to figure out what is happening?
Gary
(4,350 Views)
My guess is that you are not sending a termination character. Append a CR or LF to the command. You can use the constants on the string palette or if you right click on the string control/constant, select '\' Code Display and use either \r or \n
(4,339 Views)
I tried concatenating a CR onto the string but no difference in response.  I also tried concatenating a LF to the string but it still times out.
(4,334 Views)
Try appending both.
(4,331 Views)
That worked!!  Thank you so much.
(4,327 Views)
