serial port data reciever abnormal.
Hi,everyone I am using NI PXI 8431/8 serial card.
I got some problems.
there are 8 ports on this card.
I use this card to recieve datas on RS485 bus in 4-wire 422 mode with pin 4&5.
When I use the ports to recieve a 3-Bytes Frame as Hex 33 07 19.
Port 1~5 can get the right data.While port 6-8 get Hex 33 00 19.
But it seems that all the port can work correctly when I got the ports sending and recieving datas themselves.
Can someone explain this,
or tell me how to analyse the problem?
Baud rate 38400.
Thanks.
Neko
(3,276 Views)
as your tested, don't think there is any problem with the hardware,maybe u can try other orders or data to see if all the data with the same problem.
(3,263 Views)
