signal generator
I don't know why you want to do so. Actually the driver (if downloaded from NI IDNET) you are using is certified and has been verified. If you are really concern about the actual data the instrument is using, you can check the command with the support engineer from the manufacture.
Message 11 of 11
(614 Views)
