spectrum one CCD3000 needs some kind of post processing?
hello,
i used the labview drivers set to adquire a spectrum from a CCD 3000, no matter monocromator position or slit aperture i always get some kind of this. my question is, this signal requires corrections such as dark current, QE, etc or the CCD gives the signal  corrected.
other ideas?
thanks
(2,862 Views)
Hi, which are the functions in LabVIEW that you are using to generate the graphic
(2,811 Views)
