using hp33120a driver
I am trying to control a hp33120a function generator via Labview and a GPIB/USB interface wich is an Agilent 82357a. Therefore I installed the driver for it with a NI support engineer. here is the link : https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E96B8659CE034080020E74...
However when I run the getting started.vi of the driver with the correct gpib address (I may be wrong!!) the following error occurs :
Error -1073807195 occurred at hp33120a Initialize With Options.vi
Possible reason(s):
Driver Status:  (Hex 0xBFFF00A5) Primary Error: (Hex 0xBFFF00A5) The interface type is valid but the specified interface number is not configured.
It seems that I have to configure something but I don't know what!
Could anyone help me on that?
Boris.
(5,360 Views)
Try setting the tulip passport as mentioned by JLS in this post. You might also want to read this.
Message Edited by Dennis Knutson on 11-14-2006 06:42 AM
(5,354 Views)
Thanks! That is exactly what I needed, Everything works properly now.
Thanks again,
Boris
(5,330 Views)
I have a HP33120A and GPIB-USB with drivers installed. When I open .vi generate wfm file for hp33120a, and run tht , in visa resouces name ( COM1, COM6, LPT1)  it is not showing me GPIB resource name to select
what should I do so that , I can able to see GPIB in .vi files to select
Thanks and Regards
Ashish
(4,452 Views)
Hi Start a new thread. Do not use this old one.
And what did you see in MAX. Is it a NI-GPIB-USB or from another vendor?
But anyhow start a new thread with these answers.
greetings from the Netherlands
(4,447 Views)
(4,447 Views)
