stepper motor control +parallel port
yeah i have upload it. But i need to read some pins of the parrallel port then i should use VISA Read and then how can i configurate the number of the pin?
Message 41 of 45
(1,456 Views)
I'm not sure you can read. If you can, you would read all 8 data pins at once. The string returned can be converted to a U8 with the typecast or String to Byte Array.
Message 42 of 45
(1,454 Views)
@mriwah wrote:
could you please send me a blank.vi allowing me to read and write from a parallel port. Im not getting what you mean 😞
GCentral
Message 43 of 45
(1,451 Views)
but in a parallel port we have a data register which is my output (so im going to write on these 8pins) and a status data which is my input that i should read (4pins)  so ? an idea to read them?
Message 44 of 45
(1,448 Views)
My memory was correct about not being able to read with VISA - http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
Better to get an inexpensive digital I/O device.
Message 45 of 45
(1,433 Views)
