tektronix TDS 3054 communication
Hi,,
I want to acquire data for Tektronix TDS 3054 via GPIB to USB adaptor, it works properly when I use it with Labview signal express but I want to acquire the data into labview 2009 so I can insert it into ultrasonic A-scan VI
when I use the functio IVI acquire it detects no device!
Message 1 of 41
(6,138 Views)
Have you tried the LabVIEW driver? The IVI driver should work though. Is this the same pc you were running Signal Expess on? With the IVI Logical Name control, are you able to see the instrument?
Message 2 of 41
(6,116 Views)
NI device drivers which have been supplied in a DVD with other labview components are installed.
It is the same PC that I use for running both programs.
I did not try IVI liogical name, I ddo not even know how o do that!!
Thnx
Message 3 of 41
(6,099 Views)
Try the LabVIEW driver. Don't see much point in using the IVI one unless you use the IVI Scope Class driver.
The front panel logical name control has an arrow on the right side. Click on it to get a list.
Message 4 of 41
(6,093 Views)
Now it detects the tkds 30xx but gives no signal on my xy graph,,,it gives squire signal on wave form graph but it is not the actual signal generated by the scope
Message 5 of 41
(6,089 Views)
An XY graph seems a poor choice to display the signal. A regular graph is normally used. Post your code.
Message 6 of 41
(6,087 Views)
I need to insert my on data instead of (Scan Data) on the block diagram.24260i5A6003155547FCF8
Message 7 of 41
(6,084 Views)
I have no idea what that is. It's an image, not code and the image is of two unknown VIs. You don't seem to be graphing the output of the scope anywhere
Message 8 of 41
(6,082 Views)
this is the front panel of the above block diagram24264i0351CF711A3F7FEF
Message 9 of 41
(6,080 Views)
This is related to your other thread, where you also did not post any code and the exact same front panel image. You don't show anything related to a scope acquisition at all. Don't know what kind of help anyone give with so little information as to what the problem actually is.
Message 10 of 41
(6,073 Views)
