the gpibtsw utility continues to complain and ask to reinstall
I am attempting to install the GPIB and VISA libraries on Linux.
Red Hat Enterprise Linux WS release 3 (Taroon Update 6)
Linux marlin.stratalight.com 2.4.21-37.ELsmp #1 SMP Wed Sep 7 13:28:55 EDT 2005 i686 i686 i386 GNU/Linux
When I run the gpibtsw tool, it complains the software is not installed, that I should reboot, and re-install. I have done this several times already and I think I'm stuck in an infinite loop. 😉
Any suggestions? I simply following the INSTALL script, and everything seemed to go fine.
(3,422 Views)
BTW, This is in the messages log:
Dec  6 05:42:04 marlin rc: Starting gpibenumsvc:  succeeded
Dec  6 05:42:05 marlin nipalsm: [libnipalu.so.1.9]  Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Dec  6 05:42:05 marlin nipalsm: [libnipalu.so.1.9]  Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Dec  6 05:42:05 marlin nipalsm: [libnipalu.so.1.9]  Warning: source/package/posix/ulibEntry.cpp:192 - initialize: unable to load NI-PAL. status=-50204
Dec  6 05:41:48 marlin : hIk    æn
Dec  6 05:41:48 marlin : facility local7
Dec  6 05:41:48 marlin last message repeated 2 times
Dec  6 05:41:48 marlin : (<m    (æn
Dec  6 05:41:48 marlin : # lines preceded by a '#' are comments
Note that some of the entries are garbage.
(3,421 Views)
You may want to look at the following Knowledge Base.
http://digital.ni.com/public.nsf/websearch/0510D6744D3522298625707E004CF31B?OpenDocument
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,406 Views)
