‎11-13-2006 09:34 AM
Jp1 is connected to GND...
i have make the test and iblines give me
EOI ATN SRQ REN IFC NRFD NDAC DAC
0 0 1 1 0 0 0 0
‎11-13-2006 09:38 AM
‎11-13-2006 09:52 AM
‎11-13-2006 09:55 AM
‎11-13-2006 10:07 AM
J7 is no connect , is it an alternative ieee connector to J6.. whe use j6 or j7
Yes i have verified and it is true.....
tnt power of and cable connected to pci Gpib -> SRQ = 1
tnt power of and cable no connected to pci Gpib -> SRQ = 0
‎11-13-2006 10:26 AM
‎11-13-2006 10:35 AM
‎11-14-2006 08:08 AM
I have measure the resistor between the SRQ and GND I got a infinite value
I do the same whit the other lines(ATN,EOI,IFC,NFRD,NDAC,DAV) whit the same result, I thing none is short circuit, i have done all the measure by power off.
I alwas make this tst
I writw 0xFF to BCR Write(0xFF, BCR), I measure the voltage at the control lines pin and do a iblines at host
and I have doese result
BCR=0xFF
EOI= 0.3v, ATN=3,3v, SRQ=0.3v, REN=3.3v, IFC=3.3v NRFD=0.3v, NDAC=0.3v and
DAV= 0.3v
and iblines
EOI ATN SRQ REN IFC NRFD NDAC DAV
0 0 1 1 0 1 1 0
it look like BCR don't workt corectly?
‎11-14-2006 09:12 AM
‎11-14-2006 10:27 AM
