unable to load gpib-32.dll when running the visual basic 2008 program
I installed NI-488.2 into my PC, window 7 64 bit OS.
In the program >> project> add reference>.NET, I successfully add the NI.4882  into my visual basic  program.
By the way, this program worked well in another window 7 32 bit PC.
But when I run the program at ildev(BDINDEX,.........), error comes up as "unable load DLL gpib-32.dll".
So when I looked at c:\windows\system32, I can not fine gpib-32.dll.
Doesn't  NI-488.2 driver install gpib-32.dll?
How can I install gpib-32.dll?
(5,291 Views)
http://digital.ni.com/public.nsf/allkb/9D74098B0AFB1D2286256EF40063B3E2
(5,278 Views)
Nyc, thank you for your reply.
By the way, I think I did all the link explained.
So I have no problem in  adding  NI488.2 to my program's reference using "add reference".
The problem is GPIB statement like ildev() looks for "gpib-32.dll".
But there was no gpib-32.dll installed in "c:\windows\system32" so error comes up with "unable to load gpib-32.dll".
I did the same procedure in my another PC(window 7 32 bit OS,my current PC is window 7 64 bit OS), and in that PC I can see the gpib-32.dll in that directory and program run without problem.
I do not know how gpib-32.dll was installed in my previous PC.
Seong
(5,267 Views)
Seong
Have you looked at the example programs for .NET that install with NI-488.2?
You need to start thinking in terms of .NET
(5,257 Views)
