12-20-2012 12:39 AM
Facing some installation issues that require your support.
Tried to install NI-488.2 to windows 7 and there is an window
pop up. See attachment.
Can advice is there a window patch to resolve this issue?
Mike.T
Solved! Go to Solution.
12-20-2012 10:20 AM - edited 12-20-2012 10:26 AM
Was the version you installed compatible with Win 7? What version was it?
-AK2DM
12-20-2012 11:45 PM
Hi AK2DM,
Thanks for the reply. I tried using version 2.5. I believe this version is not for windows 7.
Also downloaded the ver 3.1. But still cannot get the installation done. New error msg.
Please refer to below.
Is it due to hardware issue? My hardware version is from YR2006
Mike.T
Error msg
Unsupported version of National Instruments system component detected
A version of a National Instruments system component that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information.
Unsupported version of NI PXI Platform Services detected
A version of NI PXI Platform Services that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information.
Legacy NI-488.2 Software Detected
A legacy version of NI-488.2 has been detected. You must exit this installer and uninstall the legacy NI-488.2 software before you can install this software. To continue without exiting, you must deselect the NI-488.2 feature.
Unsupported version of NI-488.2 for Windows detected
A version of NI-488.2 that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. For more information, refer to ni.com/info and enter 'CleanVista' as the Info Code.
Unsupported version of NI-VISA detected
A version of NI-VISA that is not supported on this operating system has been detected. You must cancel this installation and uninstall the older version before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information.
		01-11-2013
		01:33 AM
 - last edited on
		11-02-2025
		10:59 AM
 by
			Content Cleaner
Managed to solve the issue.
I uninstall all NI programs (Need to ensure all traces of NI programs is removed).
Below website can help to guide in removing all NI programs.
Then I proceed to install the latest NI-488.2 ver 3.1, followed by the hardware installation (GPIB card).
Lastly the Labview 7.1.
Testing now to see if my old labview software and hardware can work smoothly in windows 7....
Thanks for the support!
12-03-2013 07:03 PM
I am assuming that everything worked fine and you were so excited that you never came back to the support blog to let everyone know that after testing everything worked perfectly. So just asking before I un-install all NI products-did this work? I have LabVIEW 8.2 and am getting the exact same messages. Anyone out there know?
Thank you.
04-26-2015 05:23 AM
hi every one ;
I have the same problem, I want to install VISA 5.0.3 but during the installation I faced this error msg
A version of NI PXI Platform Services that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information. """
I used window7 x64
I need help
thx
04-26-2015 08:16 AM
04-26-2015 01:31 PM
04-26-2015 02:00 PM
04-26-2015 02:05 PM
