NI-488.2 installation issue for windows 7
Hi
How can I know that I m using USB-GPIB HS? And when I try to uninstall the ni 488 driver I go to the control panel but it wasn't appear as a driver with the others program
Sorry for my english it not my language mother
Message 11 of 86
(4,022 Views)
Hi
Yes I m using labview with it
Message 12 of 86
(4,020 Views)
It should be pretty obvious whether you are using the USB-GPIB,HS - http://sine.ni.com/nips/cds/view/p/lang/en/nid/201586
All software is listed under National Instruments when you try to remove it.
Message 13 of 86
(4,017 Views)
What is the ni 488 driver ? And why I need to install it?
Message 14 of 86
(4,015 Views)
Hardware needs a driver to work.
Message 15 of 86
(4,006 Views)
Ok
So as I understand
first of all is to uninstall all the ni software then I install the ni 488 drivers and ni visa finally I reinstall the labview ?
Message 16 of 86
(4,002 Views)
Under the start menu under the LabVIEW menu do you see a 488.2 menu? If you don't have this menu under the start menu under the LabVIEW menu you need to install the 488 driver. If you see the 488.2 and your 488 hardware is not working you need to uninstall it and install the 488 driver that came with your hardware.
Message 17 of 86
(3,976 Views)
Start menu
NI-488.2
If this is these run the "GPIB troubleshooting utility"
It should see your 488 hardware otherwise your driver needs to be changed
Message 18 of 86
(3,974 Views)
hi thx
no I didnt see the ni 488 under the labview , so I will install it without uninstalling the ni software??
Message 19 of 86
(3,963 Views)
The software installed is listed in MAX. It is not something you will see in a LabVIEW menu.
Message 20 of 86
(3,956 Views)
