visa error 1073807298
Hello All,
I receive VISA ERROR -1073807298.  I have followed the directions on this help page provided by NI.
http://digital.ni.com/public.nsf/allkb/60DDFED7EFEFE7188625705700750821
Unfortunately, this does not solved my problem.  Any suggestions are welcomed. My VI is attached to the post!! Thank you for the help!!
I do need to get this program working soon.  Please anyone with help, I would greatly appreciate it.  Thank you!!
(6,719 Views)
I also upgraded to VISA 3.4.1 at this moment to see if it solves my issue..
(6,715 Views)
do you have a correct cable, straight or twisted?
greetings from the Netherlands
(6,704 Views)
EngineeringEE:
What was the outcome of upgrading drivers and what devices are you using? There are read-me files accompanied
with the driver downloads if you are not sure which driver matches your device. So you are correct in trying
to make sure you have the right driver in the first place.
Are you getting this error after a VISA Read/Write like mentioned in the error document you found? I was
unable to execute the VI you attached, so if you could send a JPG screen shot, that would be helpful. Try
using highlight execution and probes to follow your data and find the source of your errors.
Have a great day.
Tori W.
(6,688 Views)
This fixed my problem on a Eurotech single board computer
(6,360 Views)
