Using Agilent 82350 GPIB and NI MAX s/w
I wish to use this agilent card with NI Max s/w, but when in run the NI-488.2 Getting started wizard the GPIB h/w is not listed.
I have checked in sytem/hardware and verified the card is installed correctly.
Message 1 of 10
(6,289 Views)
Rob,
NI MAX is written for use with National Instruments drivers and hardware exclusively.  Hope this helps.
Scott B.
GPIB Software
Message 2 of 10
(6,280 Views)
I have the same problem:
The "Agilent IO Libraries Suite 14.2" should route the NI-488.2 commands natively over the Agilent card (82350B), if "Enable Agilent GPIB cards for 488 programs" in the "Agilent Connection Expert" is checked, but no NI-488.2 Device was found in the MAX.
Message 3 of 10
(6,004 Views)
You can get MAX to see the GPIB board per this but you can't configure it there and I don't think you can use the Scan for Instruments. That uses low level GPIB commands for NI boards. You have to use VISA.
Message 4 of 10
(5,998 Views)
It seems, that the PCI-Board HP82350B works without the MAX. The item in the Agilent IO is enough. Thank you for reply.
(The NiVisaTulip.dll have to be enabled in the MAX)
Message 5 of 10
(5,992 Views)
hi,
i am using the same agilent 82350B PCI GPIB card for an application.
it is not showing in NI MAX. and i installed agilent io libraries suite, where i am  able to see all the devices connected in GPIB.
i have developed application using LabVIEW. my doubt is, do i need make any changes i code,since it is agilent GPIB card. please clarify
thanks in advance
phani
phani srikanth
Message 6 of 10
(5,198 Views)
Did you follow the instructions above about adding tulip support so that it appears in MAX? As long as you use VISA functions and not GPIB, your program should work.
Message 7 of 10
(5,196 Views)
thanks for your reply.
i have created installer for my application and installed in new pc and am not getting any options in NI MAX to do tulip process.
is this process in to only see that hardware in MAX?? or to use in application(labview) also?? please clarify
Thanks in advance
phani
phani srikanth
Message 8 of 10
(5,193 Views)
To the best of my knowledge, you want it to show in MAX so you can use it in LabVIEW.
Message 9 of 10
(5,189 Views)
yes.. its working. i am able to see in MAX
phani srikanth
Message 10 of 10
(5,182 Views)
