visa read & write
How can I use visa (serial port) to write in COM and read from another.
(4,567 Views)
What language are you using?  C++? C#? LabVIEW? LabWindows/CVI?
Regardless, there should be some really good examples available to you.
GCentral
(4,565 Views)
i'm using labview
(4,563 Views)
Then look in the Example Finder (Help->Find Examples) and do a search for Simple Serial Write & Read.  It is an ok example of how to perform a write to an instrument and then read data coming back from it.  You should be able to easily expand it to write on one port and read on another.
GCentral
(4,538 Views)
