visa write works for single device version but not for multiple device version
these VIs are used to output to the following device
http://www.tti-us.com/rc/products.htm
for the single device version the setup works perfectly.  However, the multiple device version does not.  it outputs properly once at the beginning of the program and then does not do so again.  I have no clue what is wrong.
(4,678 Views)
What do you mean but "not working". Do you get an error? If so, what is it? Is there sent over the virtual serial ports that are created?
(4,670 Views)
What I mean by "not working" is that the connected device does not receive any data
the error is
-1073807298
VISA Write in iCopterv17.vi->icopter ntest.vi
(4,632 Views)
I would suggest doing a search for that error code. This comes up frequently, and unfortunately, there could be several reasons for that. In fact, I just finished posting a reply to someone else who has the same error code.
(4,629 Views)
尊敬的各位工程师您们好:
      最近我在用NI公司的MEASUREMENT STUDIO做实验,这两天遇到一个非常头疼的问题,我在VC6.0的环境下用VISA对仪器进行控制,已经正确的添加了头文件和lib,开始时是能够实 现对仪器的控制的,但我不知最近我对电脑进行的什么操作改变了什么,突然间不能控制仪器了,而用Agilent IO control中的VISA Assitant仍能够实现对仪器的控制。(我用的是GPIB仪器,仪器与计算机之间应用网关E5810来连接的)
      望您能够解答我的困惑,现在实验停滞不前,所以很着急,万分感谢各位的关注!
(4,612 Views)
    经过排除分析和对IO接口软件菜单的全面探索,我的问题已经解决了,是自己的IO配置问题,原来它的INTERFACE是分LAN和REMOTE两种的,两种的仪器地址的写法不一样,要严格遵循。谢谢大家
(4,606 Views)
For others: The above two posts had nothing to do with this topic. The poster was asking something about Visual C. Have no idea how they ended up in this thread.
(4,603 Views)
