wen i write into a serial port and read the port it returns no respnse?
hi.
i did try using hyperterminal it works there. im using some basic AT commands like AT+CPIN? and ATD<no> to check for sim and dial a number respectively. The cable i am using is good as it works with other softwares.
Message 11 of 15
(1,694 Views)
Then attach the code with one of your commands saved like I asked. You are perhaps not sending a correct termination character.
Message 12 of 15
(1,681 Views)
i have attached an email with the string? do i need to have any data flow? i have tried the string with \r\n ,\r and \n as termination charecters but it still doesnt work.
Message 13 of 15
(1,657 Views)
You haven't attached anything. The only thing you attached in an earlier post shows that you cannot be sending either \r or \n correctly. The string control is not set for '\' Codes Display. Right click on it to change.
Message 14 of 15
(1,647 Views)
sorry guess it dint get attached
Message 15 of 15
(1,633 Views)
