12-08-2014 08:09 AM
hello,
I'm beginner in PXI module using.
I bought a PXI solution for use it as a custom instrument.
My aim is to read RTDs and command some line using relays.
So i take the system below:
NI PXIe 1071
PXI-8100
PXIe-4357
PXI-2564
I can see all the material on NI MAX.
In MAX, i can read RTD a channel value and can operate relays.
i have read and practice exercice on "Getting started with Labview RT module" and all it works,But i don't find any resources or exemple to deal with relay card or read RTD.
I have try to access it using "visa connect" and this step works, but what must i do to go further.
In a first time i want to swap relay position, by reading position, invert value ,set position and return the value.
And for RDT i'll want to make a simple measure and make a average a N measure for 1 or all input.
Can you give me some exemple or trick?
Best regards
12-09-2014 02:32 AM
What software do you use? what version?
Have you look into the LabVIEW Example Research with KeyWord "Relay". There are examples with NI-DAQmx and niSwitch drivers.
Brice S.
National Instruments France
12-09-2014 03:41 AM
for programming de PXI-8100 i use labview RT.
i have try to use ni-switch but i have a error message because ni-switch don't work with labview RT.
i have try to search exemple in LV with "relay,2564,etc etc " and i don't find any exemple.
12-09-2014 11:07 AM
Open LabVIEW, select Help>>Find Examples. On the Browse tab click Hardware Input and Output>>DAQmx>>Switch>>Immediate operations and choose one of the examples. Most of them can be run on Real Time.
Hope this helps
