where will i find drivers for the agilent spectrum analzyer
Hello All,
I am using spectrum analyzer of agilent company (E series ESA, E4402B), i want to read all the data from spectrum into my PC so which drivers to use i dont know. If anyone knows i will be very glad.
Thanking you,
pals
Message 1 of 10
(4,630 Views)
In LabVIEW, go to Tools>Instrumentation>Find Instrument Drivers or go straight to the Instrument Driver Network.
There are IVI and LabVIEW project style drivers.
Message 2 of 10
(4,626 Views)
Thanks a lot...
I got the required Drivers but the thing is this downloaded drivers i need to copy in C:/programs/national instrument/ Labview 8.5
Which i have done when i have used Rsspecn drivers for R&S Spectrum? How can i see vi's related to this drivers. i opened certain examples but few VI i was not able to see so???
Hope i am clear in my problem.
Thanks in advance....
Message 3 of 10
(4,576 Views)
You did not follow the instructions correctly if that is the path. You need to place the driver in the instr.lib folder.
Message 4 of 10
(4,574 Views)
Yup... I did it.... Thats why i asked as i was not able to see....
Message 5 of 10
(4,571 Views)
Well, you said you placed it in C:/programs/national instrument/ Labview 8.5 and that's not correct. If you actually did place it in the inst.lib folder, there should be a folder under that called 'Agilent ESA PSA Series' and under that are 'Examples', 'Private', 'Public' folders, some 'Agilent ESA PSA Series' files, and a dir.menu file.
If you want, use windows explorer to show the contents of your instr.lib folder with every thing related to the Agilent folder expanded. Take a screen shot, save it as a png file, and attach it.
Message 6 of 10
(4,566 Views)
Ya in same folder i have placed... and i need to program to get the screen shot of the Spectrum....
Message 7 of 10
(4,563 Views)
Why do you need to program anything? You just need to press Alt-Prnt Scrn. Open Paint and do an Edit>Paste.
Message 8 of 10
(4,561 Views)
No u didnt get it...
I have to see the Spectrum for different freq on Spectrum analyzer and for each freq i need to capture the screen and that which i have to put in excel....
Hope i am clear what i have to do in Labview....
Message 9 of 10
(4,558 Views)
What you said was "How can i see vi's related to this drivers." which I took to mean that the driver functions were not visible on your palette. Thats a lot different than not being able to see a spectrum on the instrument. I really don't know what your problem is now.
Whether you can see the functions on the palette or whether you can't see a spectrum, you will probably need to look in the manual to see whether there is a command to take a screen shot. I've always taken an image of my LabVIEW front panel as something much simpler to do.
Message 10 of 10
(4,555 Views)
