wireless ECG using bluetooth of labVIEW
HELO EVERYBODY....
 I am Communications and Electronics Engineer, working on a project related to how can the ECG signal send using a bluetooth module and detect the signal using the the laptop bluetooth and show the graph o labVIEW 2009....
i tried to do it using a 3rd party means i did connect the Tx and Rx for the module with a PIC16F877A and i found a C program and burn it in the PIC then try to test using 7 segment and decoder with the hyperterminal but the module cant reply anything in the AT commands. so when ever i press any number i cant get anything, BUT when i on the module and i can detect it by the laptop bluetooth and can create a serial port......so my questions are:
1- Do i have to use VISA to create the VI ???
2-Is it better to use DAQ NI-6008 to recieve the signal and test or use the hyperterminal ?
3-The bluetooth functions in the protocols of the labVIEW related to the bluetooth is it better to deal with this kind of applications???
any idea plzzzzzzzz
(4,597 Views)
I think your project mate has started discussing here
(4,575 Views)
sorry i had a problem with my system
(4,542 Views)
