wt2030 GPIB Can't read from WT 2030
Is out an NI GPIB controller?
Message 11 of 13
(927 Views)
GPIB connect to the meter, USB connect to the computer.
Message 12 of 13
(924 Views)
The explanation of the error number in your first post is: lost connection. So I thought your initial connection was OK, but now I have my doubts.
Do you see your WT2030 in MAX when you scan for GPIB instruments?
If yes, Run the initialize VI from the drive. What is the result?
Kees
Message 13 of 13
(888 Views)
