07-29-2009 06:36 PM - edited 07-29-2009 06:38 PM
Hi!
I've a problem with XY charts: since I want to get on the x axis a constant range of time (current time - 6h; current time + 4h), I've tried to set this property using the property nodes for x axis maximum and minimum.
But something goes wrong (the requested value id DBL, and if I pass from a time stamp to string and then to DBL i miss the information I need).
Any suggestion?
[I've posted in the wrong section; dear moderator, can you please move this post to the correct one?? thanks, sorry for the mistake]
07-30-2009
09:30 AM
- last edited on
09-17-2026
11:07 AM
by
Content Cleaner
Hi Stefano,
I want to suggest you these links that I feel good for your issue:
http://digital.ni.com/public.nsf/allkb/F85BB1749748F6CC862562D700787330?OpenDocument
http://digital.ni.com/public.nsf/allkb/7DEA2A466A4F9D2586256ACB005D0BC0?OpenDocument
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGxCCAW&l=en-US
http://zone.ni.com/devzone/cda/tut/p/id/7664
Hope this help,
M
07-31-2009 05:41 PM
I've already read them. I can't find what I need inside.
I've understood that the best for my application is to use waveform charts.
But... I need to add some continuous horizontal lines inside (like cursor).
How can I do??
08-01-2009 12:52 AM
08-01-2009 05:06 AM
Ok, that's a good idea.
So, using cursors (available only on graph), how can I hide the vertical cursor?
08-01-2009 09:03 AM
08-03-2009 02:46 AM
