xy graph - x axis range setting
Hi!
I've a problem with XY charts: since I want to get on the x axis a constant range of time (current time - 6h; current time + 4h), I've tried to set this property using the property nodes for x axis maximum and minimum.
But something goes wrong (the requested value id DBL, and if I pass from a time stamp to string and then to DBL i miss the information I need).
Any suggestion?
[I've posted in the wrong section; dear moderator, can you please move this post to the correct one?? thanks, sorry for the mistake]
Message Edited by Stefano Moret on 07-29-2009 06:38 PM
(4,900 Views)
I've already read them. I can't find what I need inside.
I've understood that the best for my application is to use waveform charts.
But... I need to add some continuous horizontal lines inside (like cursor).
How can I do??
(4,867 Views)
Hi
Either you can use a cursor that does not show its vertical line or you add a plot that has two coordinates, the begin x0,y0 with x presumably zero and y the height of the horizontal line, and the endpoint with the same y and an x of the correct value.
goodluck
greetings from the Netherlands
(4,858 Views)
Ok, that's a good idea.
So, using cursors (available only on graph), how can I hide the vertical cursor?
(4,855 Views)
You can select several types of cursor, look in the help.
(4,850 Views)
Oh, thanks.. It seems easy, but it's not difficult at all 🙂
(4,838 Views)
