LabVIEW APIs Discussions
Scripting with polymorphic VIs
I'm trying to programmatically add VIs to a polymorphic VI but cannot find any method or property that would let me do that.
I would expect there to be a property that contains children of the polymorphic VI and a method to add VIs to it, but cannot find anything like that. I would also like to set the short and long names of the VIs in the polymorphic VI as well, since that is a tedious job that is very error prone when doing manually.
Can anyone show me how that can be done?
Thanks a lot!!
Joseph
Message 1 of 13
(13,490 Views)
Not sure it has exactly what you want but take a look at this example on LAVAcr.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 13
(9,909 Views)
Merci beaucoup!! C'est ce qu'il me faut pour commencer.
Thanks! That's what I needed to start with.
Message 3 of 13
(9,909 Views)
I can now add VIs to a polymorphic VI.
Is there a way to change the properties of the polymorphic VI (adapt to type, show selector, which icon to show...)?
Can I change the selector name of each VI contained in a polymorphic VI?
The link from lavacr does not do these things.
Thanks!
Joseph
Message 4 of 13
(9,909 Views)
You need to activate scripting and make sure you have a polymorphic VI type reference, if you activate that you get the following properties:
InstanceInfo will show the information about every VI.
Ton
My LabVIEW Ideas
Message 5 of 13
(9,909 Views)
Hey,
thanks a lot. Those were the properties I was looking for. I used InstanceInfo as write node and added the paths with selector and menu names. It worked like a charm, and it's easier to manipulate than the previous solution.
Joseph
Message 6 of 13
(9,909 Views)
TCPlomp,
I can't seem to find the AdaptToInputs using LabView 2014.  It might have something to do with selecting the polymorphic VI type reference?  Any thoughts?
THANKS!!!
Message 7 of 13
(9,909 Views)
Here's a 2014 snippet.  You do need to have the PolymorphicVI class not just VI.
Message 8 of 13
(9,909 Views)
How do I find it (How do I drop that onto the block diagram)?  When I connect a property node to the "new VI" scripting command I can't find PolymorphicVI as an option.
Is it considered on object of a Polymorphic VI?
Thanks!
Message 9 of 13
(9,909 Views)
You need to cast the object (use To More Specific Class) to a PolymorphicVI.
Message 10 of 13
(9,909 Views)
